HI all,
Any help would be great,
I use the left and right arrows on my keyboard as hot keys to transition betwen videos.
When I use the CUT TRANSITION, is there anyway for it to cut VERY fast (like instantly) sort of like and an A-b switch you'd use with DVJs?
right now when I hit activate and have the cut transtion effect on, it takes a little bit and I watch the little dial go around.
I did go into the OPTIONS categories and changed CROSSFADER to CUT, really didn't help all that much.
The dial (to the left of CUT transtion in the vmix skin) still has to spin around
I have fade length at 3.9 sec but at 0 sec that made no difference and force fade I have enabled.
If you know, please let me know how to set this transition to happen so it truly "cuts" back and forth.
Thanks a bunch.
B
Thanks a bunch.
B
geposted Sat 18 Nov 06 @ 11:34 pm
crossfader , modes are for the audio not the video X-Fader
geposted Sat 18 Nov 06 @ 11:44 pm
gotcha- so those setting affect only audio and won't help me.
What about getting this to happen- is it possible?
B
B
geposted Sat 18 Nov 06 @ 11:53 pm
change the video transition to another effect
geposted Sun 19 Nov 06 @ 12:30 am
