Hi,
I did a fresh reinstall of my laptop last week, and I find that now when I play mpg videos the sound is really low compared to mp3s. I didn't have this problem before, i'm sure it's only a minor thing (like a codec problem or something) but would anybody know why?
I'm using V3.4, with a u46dj soundcard on windows XP.
Thanks for your help
geposted Sun 19 Nov 06 @ 4:29 pm
boost the gain when using the video files
it might be somthing to do with the file encoding
geposted Sun 19 Nov 06 @ 6:38 pm
Have you set the gain setting in the config menu to "Always 0dB"?
Ewout
Ewout
geposted Sun 19 Nov 06 @ 8:16 pm
Quote :
Yes, i think I might have changed that.
I'll try it out this afternoon. Cheers
geposted Mon 20 Nov 06 @ 10:36 am
Thanks Superstom, that was it.
Well done.
Well done.
geposted Tue 21 Nov 06 @ 10:33 am
