Maybe you more experienced computer guru's already know this;
but this Something I just found out.
If you make a playlist on one system, but decide to set up a second system
you can copy that same playlist to the second system without having to pick
and choose it all over again.
Just copy the original playlist and paste it into your
playlist folder on the second system.
geposted Tue 21 Nov 06 @ 8:12 pm
Yes you can, provided the songs are in the same exact folder locations on both computers. You see, the playlist function searches within folders and loads from there. If you copy a playlist to another computer and say all of your music was in the d drive on one computer and the e drive on another, none of the links will work. You want to make certain you use standard drive letters on your systems and keep your songs in the same folder names with the same file names.
geposted Tue 21 Nov 06 @ 8:21 pm
