1st off, happy thanksgiving!
After my 1st night with my real soundcard, I noticed that some songs sounded louder than others, and I used the same ripping program for 90% of them.
Audiobrabber and windows media player for the others.
Just wondering what some of you use for settings with the Firebox for volume adjustments, etc.
Also, is there a program that makes the levels even on soundfiles, so I can do it all in one batch, or is there an easy setting so that VDJ can do it for me?
geposted Thu 23 Nov 06 @ 4:14 pm
mp3gain and its free:
http://www.pcworld.com/downloads/file/fid,23022-order,1-page,1-c,alldownloads/description.html
try it out on a few files-bet u'll like it =-P
BOOGIE
BOOGIE
geposted Thu 23 Nov 06 @ 4:44 pm
I have VDJ play all videos and audio at 0db. There is a setting in VDJ Options. Make sure everything is analyzed.
They all sound the same (perfect).
Enjoy it.
Enjoy it.
geposted Thu 23 Nov 06 @ 10:06 pm
In general, VDJ's autogain works well, but I find it to be a little off on some files.
Replaygain seems more accurate. I'm guessing that they aren't the same algorithm...
Are they?
Are they?
geposted Fri 24 Nov 06 @ 8:14 pm
