I have the Hercles DJ Console MK1 which comes bundled with Virtual DJ (not sure which version). Last night I dodnloaded the trial of VDJ 4.1 and I think that the beatmatching has been improved. Is this a recirded imprivement, has anyone else noticed?
One thing about the previous version I had that when I click the beatmatch button, is needed a slight adjustment every singe time to ge the beat properly in line, I always haev to pull the jog wheel back a little - and sometimes it was very difficult to get them seamless.
Has version 4.1 made significant progess in this area?
Thanks
Thanks
geposted Fri 24 Nov 06 @ 10:48 am
version 4.1 has a totaly new and improved sound engine so yes it has :)
the mk1 console has vdj 2.0 on it
hope that helps
hope that helps
geposted Fri 24 Nov 06 @ 10:49 am
Thnaks, where ca I find further details on this?
geposted Fri 24 Nov 06 @ 4:46 pm
geposted Fri 24 Nov 06 @ 4:51 pm
You should learn to beatmatch manually (without auto features) in order to get the true feeling of being a dj. However, if you can't do this on your own yet, vdj does it perfectly for you.
geposted Fri 24 Nov 06 @ 7:09 pm
very true
geposted Fri 24 Nov 06 @ 11:25 pm
I am amazed at how long VDJ can keep the mix going without fading apart. That said, often I do tag teams at a club with other DJs and have to manually beatmatch to their music. I am able to beatmatch manually using just a keyboard with no problems.
geposted Sun 26 Nov 06 @ 7:06 am
