Got some problems i didnt had with version 3
1. automix does not run smooth, when entering a new song theres a gap at the audio, the mix is not smooth. Version 3 was very good with automix.
2. lot of songs have no bpm after bpm scan, they use with version 3
any help?
any help?
geposted Sat 25 Nov 06 @ 5:20 am
1. adjust the automix to suit your needs by pressing the bpm buttons on the side of the automix button
2. have you moved any of the files? did you back up the 3 database?
geposted Sat 25 Nov 06 @ 12:04 pm
no backup, just started fresh new installation
geposted Sat 25 Nov 06 @ 11:23 pm
then you might have overwritten you database sorry try recursing your drives
geposted Sat 25 Nov 06 @ 11:46 pm
BPM scan problems are solved once i restarted my PC.
the automix was better at 3.4 version
geposted Mon 27 Nov 06 @ 9:16 am
