Hi all,
Configuration : DJ Console + VDJv4.1r2 (i use an external mixer)
Issue : When the music play on the deck 1 and i want to synchronise the deck 2 with the left joggle, i hear a scratchy sound ON THE DECK 1 !!!
This issue is identical when using the other desk.
Thanks in advance for your help.
Regards
Regards
geposted Sat 25 Nov 06 @ 11:41 am
In fact every button i touch (sliders...) on the other deck produces this scratchy noise !!!!
Don't know what to do for my next party coming soon.
Regards.
Regards.
geposted Sat 25 Nov 06 @ 12:00 pm
After some tests:
I came back to the VFJ3.2 with the same configuration : NO PB!
My feeling is a that it's a regression of the VDJ4 release, something has probably changed in the DJ Console Soundcard management...
I've got a Work Arround (3.2 release). Any help is welcome to fix this problem.
Regards.
Regards.
geposted Sat 25 Nov 06 @ 12:40 pm
have you got the 4.1r2 update ?
not just 4.1
as this solves a few console problems
not just 4.1
geposted Sat 25 Nov 06 @ 12:46 pm
Had you the keylock activated on the deck? If so, disable it to try
geposted Sat 25 Nov 06 @ 1:16 pm
not just 4.1
not just 4.1
Sound Pb with the Joggles" DJ Console + VDJv4.1r2 oops!
sorry about that
sounds like the keylock then
geposted Sat 25 Nov 06 @ 1:22 pm
