Sup all, I was using VDJ this moring, took a nap and when use it again to record some remixes and then tried to download songs from my HD. I keep getting that lovely Fatal Crash message with the smiley face. I ty to recover from it and nothing. I get an error message of R6025. Any ideas?
MS
MS
geposted Sat 25 Nov 06 @ 5:09 pm
You tried restarting your Pc? and see if it happens again
geposted Sat 25 Nov 06 @ 5:13 pm
Yes I also reinstalled VDJ and nothing yet...:(
MS
MS
geposted Sat 25 Nov 06 @ 5:14 pm
got xp?
geposted Sat 25 Nov 06 @ 5:15 pm
Yes I do and I am using VDJ 3.4 still.
MS
MS
geposted Sat 25 Nov 06 @ 5:16 pm
go to startmenu
programs
acessories
system tools
pick system restore
choose a date about 2 days ago
and this will restore the settings of your system to this time , i think this could solve this for you
another thing to try would be to upgrade to v4
programs
acessories
system tools
pick system restore
geposted Sat 25 Nov 06 @ 5:21 pm
I will try this Sky. Thanks. BTW congrads on the VIP status. Also I don't care much for V4 due to the Effects usage. I perfer V3.4 Effects engine alot better.
MS
MS
geposted Sat 25 Nov 06 @ 5:24 pm
goodluck , thanks :)
i kinda agree with the fx thing but the new one has its merits aslo :)
geposted Sat 25 Nov 06 @ 5:26 pm
I'm back and still doing the same thing. Anyother suggestions?
MS
MS
geposted Sat 25 Nov 06 @ 5:32 pm
Delete your registry entries for VDj then reinstall
Start----Run "type in the box" "Regedit"
Since your using only 3.4 the entries should be under
HKEY_LOCAL_MACHINE / Software
find the whole VirtualDj folder right click and delete it you can also check for entries in the HKEY_CURRENT_USER / Software
geposted Sat 25 Nov 06 @ 5:33 pm
I will give it a shot.
MS
MS
geposted Sat 25 Nov 06 @ 5:34 pm
cool
becareful mistakes will crash ur pc bigtime
geposted Sat 25 Nov 06 @ 5:44 pm
Tried it and still the same thing. :(
MS
MS
geposted Sat 25 Nov 06 @ 5:47 pm
The Support Team should have a list of error codes, so they can get it up for you quickly or know right away what it is causing it
geposted Sat 25 Nov 06 @ 5:49 pm
Thanks guys.
MS
MS
geposted Sat 25 Nov 06 @ 5:51 pm
PC + lake + strong arm = problem sorted... for the meantime :D
Jokes, but i wonder why it gives a cheeky smiley face??
geposted Sat 25 Nov 06 @ 5:52 pm
Lol , Good point maybe it should be changed to an aggrevated face
geposted Sat 25 Nov 06 @ 5:59 pm
Well it seems that it's a Windows Xp error not a VirtualDj error, just google windows xp error r6025
geposted Sat 25 Nov 06 @ 7:10 pm
dont suppose you have aol software on your pc , that aparently can cause it
geposted Sat 25 Nov 06 @ 7:20 pm
try to dissable some of the programs that start during the boot
start -> run-> type msconfig and go to the startupfolder,dissable all,then go to services and check hide all microsoft services, disssable all services that you don´t need,apply and reebot your computer...most of the microsoft errors has to do with startup processes
I did a googel on the error and it says that it can be caused by some java based applications & other visual bacis c++ shit sfuff
geposted Sat 25 Nov 06 @ 7:24 pm
