I recently purpchased DJMIX Station 3 and whenever I trying to load tunes from my hard drive it comes back with this fatal error or recover. I try to recover but the prog bombs out, can someone please try and help me with what i need to set in order to stop this from happening.
Many thanks
John Stewart
Many thanks
John Stewart
geposted Sat 25 Nov 06 @ 10:24 pm
have you tried a reinstall ?
geposted Sat 25 Nov 06 @ 10:33 pm
Yes, I diusabled my anti virus and spyware software and uninstalled and reinstalled, started DJMistation3, but when I went to scan the same fatal error occurred and clicking on recovery just booted the software.
Next step please, maybe there are some bug fixers to solve this problem?
I await your advices.
John Stewart
John Stewart
geposted Sun 26 Nov 06 @ 9:34 am
what os are you using ?
if your using xp
uninstall
go run and type "regedit"
then use the box called search for virtual dj
delete all the keys for this then install again
should be fixed
when did you get your copy btw and where from , im trying to get a copy my self but every where seems out of stock :(
if your using xp
uninstall
should be fixed
geposted Sun 26 Nov 06 @ 12:11 pm
I am operating Win XP Home with all its updates.
I ran through the uninstall, search and run and reinstalled it again with the anti virus disabled, but I am getting the exact same fatal error again.
I live in South Africa and i actually bought this about 5 months ago, but have not had time to get into it until now, and I am concerned that I may never get it to work. Any more suggestions or maybe a bug fix?
Many thanks
John Stewart
Many thanks
John Stewart
geposted Sun 26 Nov 06 @ 9:48 pm
could you upload a screenshot
and post a link to it on the forum of this error
here
here
geposted Sun 26 Nov 06 @ 9:50 pm
