Hi all,
Just curious if anyone has the same probs as me or even has a solution.
I originally thought this problem was linked to my icdx but on the weekend I decided to run bone dry on the laptop and use keyboard styles, no nuo4 or icdx via usb connected & also using an old school dual cd rackmount as a backup.
Problem that is occurring is whilst a song is playing on 1 deck, the song that I am cueing up by moving the platter forward or backward affects the song that is playing. It sounds like it is doing a pitch bend according the movement of either forward or backward. I notice it quite badly when I rewind or fast forward the platter quickly. Note I am using the mouse to move the 'virtual platter' on the default skin for movement. The problem also happens when im using my icdx to rewind and fast forward.
I have tried adjusting my performance settings but the problem still occurs. I adjusted it so far that the latency from when I push play on a deck, the delay is quite long its ridiculous.
I have just upgraded recently to v4.1r2 from v3.4. I had a separate installation of v4 and v3.4 running but I couldnt install the update to v4.1r2 because it was looking at the default installation directory which was 3.4. I was forced to upgrade, so now I'm solely using v4.1r2. I havent had any problems in v3.4... I also have disabled stuff I don't use in the windows device manager as well as in the bios in case anyone is wondering.
Any help would be appreciated.
geposted Sun 26 Nov 06 @ 11:01 pm
