Please help me hook up the gigaport ag and dac 3 to the Virtdj 4
Thanks
Thanks
geposted Tue 28 Nov 06 @ 2:52 am
gigaport as soundcard
tick dac 3 as contoler on remote control tab
geposted Tue 28 Nov 06 @ 10:58 am
You need to enable the DAC-3 in VDJ's config/remote control tab as above.
When you purchase the pro version of VDJ, you will be able to download my custom mapper for the DAC-3 that enhances its functionality, allowing you to control most functions of VDJ directly from the DAC-3, including file browsing, effects, video mixing/effects/transitions and samples.
geposted Tue 28 Nov 06 @ 6:57 pm
