Is anyone using this soundcard, and if so, are you having any luck with it? How did you set it up? I tried it the other night and got some really weird popping sounds through it while any track was playing, from either deck. Went back to the onboard soundcard and all was fine. Kind of defeats the purpose of having a multi-channel card though.
Also, if you are using an Echo MiaMidi, which driver version are you using so it works well with VDJ?
geposted Tue 28 Nov 06 @ 7:34 pm
