Hi all
I used my virtual dj 4.1r2 pro with my MK2 last week and everything worked fine, but when I open it today it doesn't analyse the songe anymore and the rhythm windows is blank except for the squares that indicates the beats, If I touch the Rhythm window using the mouse the program freezes and I have to kill it in tast manager. It also freezes if I bring the pitch up and down a couple of times
I've tried to reinstall but that doesn't change anything. I've tried to use it without my MK2 (after a restart of the computer) but it still doen't work
I don't think I have changed anything on my laptop since the time where everything worked fine. What have happen to my poor machine and software?
Regards
Klaus Mogensen
Regards
Klaus Mogensen
geposted Tue 28 Nov 06 @ 10:53 pm
try this go to startmenu
programs > system tools > system restore
you will be asked to chose a restore point chose the closest one before yesturday
and press next your computer settings will now restore to this time
hopefuly solving the problem :)
geposted Tue 28 Nov 06 @ 10:59 pm
Thanks. It worked
And it also helped me figure out what had happend. 'Cause it's never nothing now is it :)
A couple of days ago I read about making the EQ work in the headphones, at I downloaded the registry_tool and changed the setting but didn't test it. And it turns out that as soon as I use the registry_tool my VirtualDj stops working no matter what I do - so I guess this tool is not for me :-)
Thanks again!
/Klaus
Thanks again!
/Klaus
geposted Tue 28 Nov 06 @ 11:48 pm
glad to hear its fixed :)
geposted Wed 29 Nov 06 @ 11:54 am
