i just brought my first mixer (Staton M.303) and i can't hook it up to my computer
i can't get it to work, do i need some kind of usb interface? (i don't have a tt or vdj)
i plan on mixing it on virtual dj
First I plugged in my RCA-to-1/8" Y adapter to Line in 2 (on sound card)
then to L/R of my Line 2 on mixer
setting it up 4.1 in virtual dj
geposted Wed 29 Nov 06 @ 11:11 pm
geposted Wed 29 Nov 06 @ 11:16 pm
you need two output channels to use with dual phono
so if you have two outputs
you can use one of these mini jack to dual phono
in sound config choose two output channels
geposted Wed 29 Nov 06 @ 11:20 pm
okay i hooked up the red and white wire to PH1 (Phono 1) and the green wire to LINE IN 2
now i can't find two output channel
geposted Wed 29 Nov 06 @ 11:41 pm
is ur card 4.1
look for a main output and a second output if you dont have this u need an external card such as a u46dj
geposted Wed 29 Nov 06 @ 11:54 pm
i have creative x-fi fatality fps
Card Connectivity
FlexiJack (Performing a 3-in-1 function, Digital In / Line In / Microphone) via 3.5mm mini-jack
Line level out (Front / Rear / Center / Subwoofer) via 3 X 3.5mm mini jacks
AUX_IN line-level analog input via 4-pin Molex connector
26 pin AD_Link connector for linking to the X-Fi I/O Console (upgrade option)
I/O Drive Connectivity
2 x RCA jacks for coaxial SPDIF input and output
2 X RCA jacks for Auxiliary input
2 X optical connectors for optical SPDIF input and output
2 X mini MIDI female connectors for MIDI input and output
Headphone output via 6.35 mm (1/4-inch) stereo jack
Shared line-level analog Line/Microphone input via 6.35 mm (1/4-inch) stereo jack
Card Connectivity
geposted Thu 30 Nov 06 @ 12:02 am
my card is 5.1... my speaker is logitech x-530 (5.1)
i hope this will work, otherwise i have to return this :(
geposted Thu 30 Nov 06 @ 1:01 am
after X hours of messing around
i finally got it, i took the GREEN wire to stereophone on my I/O drive
the other RED & WHITE to Phono1
i was able to hear anything i adusted on the mixer during VirtualDJ playback
however i can't record what i mixed, it only play back normally without my mix
i need another cable of the same?? and hook it up to microphone (Line 2)?
geposted Thu 30 Nov 06 @ 5:47 am
does the card have a line in if it does higher quality mic in will only be mono :(
geposted Thu 30 Nov 06 @ 10:16 am
it does.... have severals actually, read my 2~3 posts up
now i just have to figure it out how to record my actual mix
geposted Thu 30 Nov 06 @ 9:02 pm
use the aux phono input
geposted Thu 30 Nov 06 @ 9:05 pm
crap now i have an annoying buzzing sound
i didn't change anything, and how would i connect the AUX?
there are one white and one red on my I/O drive
geposted Fri 01 Dec 06 @ 12:08 am
damn it is there anyway to edit my post?
i connected the mini-rca y cable from "RECORD L/R" (mixer) to Line 2 (i/o) drive
and i get that annoying buzzing sound
how can i record?
how can i record?
geposted Fri 01 Dec 06 @ 12:10 am
