Forum: Old versions
Topic: mk2 on a mac - Page: 1
hi there...i know mk2 is supposed to be pc only...i have bought it 2 months ago but now i have bought an imac...are there any drivers to at least use it as a multi0-soundcard?
any plans to release mac drivers for mk2 by hercules?
u think it might work in parallels desktop for mac?
thanx
geposted Thu 30 Nov 06 @ 10:13 am
can you dual boot with bootcamp?
yes u can have bootcamp, but the purpose of buying the imac is to use macosx and not windows again:-)
true but there is no mac driver and its unlikey that there is going to be one developed , so u gota make that call
virtual dj however will be comming to mac shortly after xmas
so since virtual is coming to mac, isnt it time for hercules to make a driver?
what were they thinking when the developed 2 different pieces of hardware??
i mean i've never seen that...2 different soundcards for mac and pc...why not have different drivers...electronic is elctronics...u dont have capacitors and resistors for pc and others for mac...
maybe you should write to their support :)
and encourage them to to make a driver
as they have a mk1 version for mac and its the same unit with a mac driver
but they did not do it for mk2
i know that they make it for mac, but i dont get it...a lot of users are switching to mac after buying and trying the product on their pc...since i paid 300euro for this, its not fair that they dont make a driver to AT LEAST use it as a multi-channel soundcard....since they say that its a multi - channel soundcard///
i emailed them and they say they gonna build a mk2 version for mac again using the same philosophy...different hardware...really stupid...i guess they are going to loose a lot of mac shitching customers...i will never buy one of their products again...
any idea if a generic asio driver for mac will work?
try asio for all but if the device isnt recognised its a tough one
I'm running winxp with bootcamp, Mk2 works like a charm with vdj 3 something.
When booting osx the soundcard in mk2 is reqognized. Tried using it as a midicontroller with ableton live but wont get it working. Having a friend over this weekend, will see if we work it out. ill keep posting. sry language, from sweden :)
Im new to mac and wish I never changed if I knew I couldn't use virtual dj!!! Anyways whats the beal with this bootcamp thing? What is it, who do I use it, and where can I get it?
http://www.apple.com/macosx/bootcamp/
There is the free software from Apple that will allow you to install (only) windows XP SP2, Home or Pro edition, on any Intel based Mac. That is how I've been running VDJ on my Mac for over 9 months now.
The Mac version of VDJ should be out soon though you won't have to use windows for long if all you're going to use it for is VDJ.
The creation of this new Mac section is somewhat indicative of that.
all sorted now
should be a good controler for the new mac edition :)
skyfxl wrote :
all sorted now
I just hope that Virtual Vinyl supports other soundcards besides Numark's own.
If not, do we have to use VirtualDJ Pro for non-Numark soundcards and controllers.
This is in part why I bought VDJ Pro for windows after the free Mac "switch-grade" was announced anyway, along with my supporting Open Source and SDK availability and their coders.
well , it will support any that mac supports basicaly
i have read about how some simpler cards like u46dj
will work ok on the default mac audio drivers
but unfortunatley i do not think asio mode is supported
Ooops! Sorry, but I went over the 15 minute time limit to revise my post and response to yours.
Here they are in their entirety:
skyfxl wrote :
all sorted now
I just hope that Numark Virtual Vinyl supports other soundcards and controllers besides Numark's own.
If not, do we have to use VirtualDJ Pro for non-Numark soundcards and controllers?
This is in part why I bought VDJ Pro for windows after the free Mac "switch-grade" was announced anyway, along with my supporting Open Source projects, SDK availability, and the coders themselves.
Also, is there any word on our ability to seamlessly integrate into an SSL environment? With the vast majority of clubs and now radio stations having Serato SL already in place, this is NOT an option and would be a BIG mistake on Numarks part in advancing it's presence among professionals here in the U.S. whether they're on Macs or not (but as we here in the US know, MOST professionals are using SSL on Macs). We need to be able to plug into an SSL environment just as easily as an SSL user can plug into another SSL users set-up.
You saw some of those event flyers that I'm on sky. How many turntablist/dj's are there on them? I see 8 on the first flyer and 15 on the 2nd flyer in this other thread:
https://virtualdj.com/forums/64014/General_Discussion/Only_1_CREW_can_bring_2_COMPETING_LA_radio_stations__TOP_TURNTABLISTS_together_.html?page=1
ALL of them are SSL users now, and I have NO chance trying to convince all of those other turntablists to let me unplug their SSL set-up so that I can plug mine in and risk killing a dancefloor with up to 2,000 people if something goes wrong, when we are all doing 15-20 minute rotations. By the time I'm done plugging everything in and configuring my set-up, it'll be time to pack it up for the next SSL user.
PROFESSIONAL U.S. turntablists and/or DJ's will NEVER switch from SSL to VirtualDJ OR Virtual Vinyl if they can't seamlessly integrate into an SSL environment! Numark can kill the integration support when it becomes dominant, but it will never become dominant if it can't let it's users integrate into the current dominant SSL set-up.
Hopefully that won't be the case though as had been mentioned previously. =)
Let us know if you know anything sky. =)
to my understanding ssl will work fine , because as i said , its a mac supported device
therfore the os and vdj can read it
but its a hopless case for some cards which where made only for windows drivers and thats the responsiblity of the manufacturer
Okay, got it! =)
That Rane Serato ScratchLive integration is ESSENTIAL for the adoption of Numark Virtual Vinyl among the professional U.S. market including the artists (turntablists/dj's), venues, and radio stations.
Glad to hear that we'll still be able to easily swap out our equipment on the fly in high pressure situations.
91%
