oh yeah....why does my vdj+bcd2000 freezes everytime i change windows (exp:vdj to yahoo messenger!) ?? thx in advanced...
geposted Fri 01 Dec 06 @ 3:14 pm
what are your pc specs and proformance setting
yahoo is a high cpu taxer
geposted Fri 01 Dec 06 @ 4:55 pm
the answer is: don't run VDj in full screen mode.
geposted Fri 01 Dec 06 @ 7:28 pm
i have P4 1,8 Gigs with 1 Gb Ram and DSL 6000
is that not enough ? what bout the latency for bcd ? i use it on 21ms....
how do i turn off vdj's full screen mode ?
geposted Sat 02 Dec 06 @ 11:02 am
choose a smaller skin say 800X600
geposted Sat 02 Dec 06 @ 11:03 am
hmm...can you recommend a good 800X600 skin ? i didnt find a fine one...there used to be an option for full screen mode in the older VDJ version...
geposted Sat 02 Dec 06 @ 11:28 am
https://virtualdj.com/addons/download.html?addon_id=2255
has an 800x600 copy in the zip
geposted Sat 02 Dec 06 @ 11:34 am
alrite..but it stil runs vdj in full screen mode´...
geposted Sat 02 Dec 06 @ 11:38 am
how anoying i will experiment
it didnt for me
it didnt for me
geposted Sat 02 Dec 06 @ 1:58 pm
Omg are you guys kidding?
Every window in Windows has a full screen mode (unless it's locked, which is in rare occasions), just click the
- like button on the skin, commonly located in the top-right corner...
And what part of this problem would a smaller skin solve anyway?
geposted Sat 02 Dec 06 @ 2:44 pm
personaly id just stop using yahoo it sucks the life from your pc
some skins start in fullscreen and wont go out of it
that way he wouldnt need to switch bettween windows all the time
just a thought
just a thought
geposted Sat 02 Dec 06 @ 4:22 pm
Nonsense. Show me one skin that overrides the program's internal setting of being in full screen mode or window mode.
Well the guy is using it and wishes to know if it's possible to solve the problem without messing with yahoo (which is), so it's not really helpful advice is it?
geposted Sat 02 Dec 06 @ 7:12 pm
true
other thing to try is to totaly lower your proformance tab
that way less cpu strain but then the music might not sound as good its ur call
pcs only can take so much strain scotty before they blow ! lol
geposted Sat 02 Dec 06 @ 7:19 pm
doooooooooooooooooooooooooooooooooooonnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnttttttttttttttttttttttttttttttttttttttttttttttttttttttt
use yahooooooooooooo its evellllllllllllllllllllllllllllllllllllllllllllllllll!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
puts viruses on ur computer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
just my idea!!!
just my idea!!!
geposted Sat 02 Dec 06 @ 8:36 pm
there is that
if you wish to use msn , aol , yahoo at the same time as virtual dj
try this
http://www.easymessage.net/
try this
geposted Sat 02 Dec 06 @ 10:38 pm
