Do all of the MK2 buttons/features on the hercules mk2 continue to function when you are connected to an external mixer?
Thanks
Thanks
geposted Fri 01 Dec 06 @ 5:47 pm
yes you must control the fx this way and play and cue
geposted Fri 01 Dec 06 @ 6:12 pm
So would I be wasting my money if I bought a Pioneer DJM-400 for instance. Would the sampling and FX on the pioneer work in addition to the MK2?
geposted Fri 01 Dec 06 @ 8:21 pm
if you buy a midi mixer then you can control with that
but if its not a midi mixer , u can only fade and mix the outputs of the two channels in the mk2
with no software control
geposted Fri 01 Dec 06 @ 8:31 pm
I am still very new to the Mk2, so bear with me on this.
When you are using an ext mixer with turntables and the time code vinyl
Do you still have the same functions of the Mk2 available, cue, fx, looping, etc....
geposted Sat 02 Dec 06 @ 2:24 am
the mk2 has control of the software
the external mixer only has control of the the output of the mk2
ie fade between A and B
geposted Sat 02 Dec 06 @ 11:07 am
I see, thanks
geposted Sun 03 Dec 06 @ 2:21 am
So the main reason to have and external mixer would be to connect turntbles or cd decks.
Sorry if these questions have been answered else where, but I am trying to get my mind around this whole digital Dj thing. Its very cool, but a little bit of a learning curve for someone just getting into it
thanks for all of the information
R
R
geposted Sun 03 Dec 06 @ 2:29 am
you could plug them straight into the mk2 thats what the inputs are for :)
geposted Sun 03 Dec 06 @ 12:06 pm
