Hello -
I have for years and years been keeping a mix list that basically shows me "song A" / "song B", with as many "song B" options as possible tracked from different successful programming choices I have done.
Interestingly, you seem to have come up with the same concept here at VDJ and have integrated it into the software so that the "list" is automatically kept and accessed easily once "song A" is loaded/playing. (At least I *think* that's what you are doing, as I am still waiting for my new software to arrive : )
So my question is this: how are you tracking the mix sequences? Are you basically using a simple algorithm to pull them from playlist logs? And, my main question: Do you think there is any way that I could IMPORT my mix list history (about 17,000 tracked mixes) for access within the Suggestion Box?
Thank you!
Adrian
Thank you!
Adrian
geposted Sat 02 Dec 06 @ 12:32 am
sorry you cannot import to the suggestion box in this manner but you can scann them so they apear in the main search the
sugestion box is the songs you play the most
geposted Sat 02 Dec 06 @ 11:17 am
thanks - i guess I'll just stay w/ my current management system via Word
Best wishes
Adrian
Best wishes
Adrian
geposted Sun 03 Dec 06 @ 11:05 pm
