when you use the nuo4 with vdj, does this eliminate the need for the Mk2 console?
geposted Sat 02 Dec 06 @ 2:26 am
to use the nu04 youl need a pro copy
and a dual output soundcard could use the mk2 as a card only for this
geposted Sat 02 Dec 06 @ 10:58 am
So I would need to purchase a sound card in addition to the Mk2?
geposted Sun 03 Dec 06 @ 2:23 am
depends on what u wana do you could dissable the control elements of mk2 and use it as a card only
or u could get a u46dj instead it depends on ur budget ;)
geposted Sun 03 Dec 06 @ 12:13 pm
