Guys I have a small problem that I need to correct. Recently I had to reinstall VDJ 3.4 because of an error. Everything works fine now but I have two issues. One...I may have screwed up and not backed up my Data base file correctly as I have lost all my BPMs. Secondly I move all my files from a previous directory after buying a new computer, but VDJ is still showing that these files exist in my song browers. In other words I have two of everysong. One song plays and the other shows an error when trying to play it because it can't read from a non existent directory. Any ideas? I know that it has to do with a data base file.
MS
MS
geposted Sat 02 Dec 06 @ 7:42 pm
open the mp3database.txt (NOT THE .XML FILE) in vdj folder . delete all the lines in the txt file - save - . open vdj right click local database - scan for music .. take 5 second and you only have one copy of every song and the song is workining - no errors
geposted Sat 02 Dec 06 @ 8:22 pm
Tried it and nothing still. I delete the info so that the .txt file 0 bites. I rescan my HD and t reverts back to the original size file.
MS
MS
geposted Sat 02 Dec 06 @ 8:30 pm
Silly replay but - did you shutdown VDJ before you did that ?
One more . are we talking ver 3.4 all the time or is it 4.1 on you new computer - The xml file in in 4.0/1 has you logon name in the name and 3.4 can´t find it or the otherway around
geposted Sat 02 Dec 06 @ 8:44 pm
have u tried pressing recurse?
geposted Sat 02 Dec 06 @ 10:21 pm
Thanks guys...
MS
MS
geposted Sun 03 Dec 06 @ 6:42 am
Did you get it to work ?
geposted Sun 03 Dec 06 @ 8:43 am
