I've been using VDJ 3.1 for a while now , no problems at all. I'm considering the upgrade to 4.0 but i'm concerned about reliability at this point. If I upgrade to 4.0 can install it in a different directory so I can still have the 3.1 and do I have to install 4.0 first and then the update 4.1r2 or can i just install 4.1r2. Can 4.1r2 be used with the Serato Interface. I Bought Serato but I don't use it . I Like VDJ much better.
geposted Sun 03 Dec 06 @ 11:15 pm
go straight to 4.1r2
in a different folder
be sure to back up databases and copy to the new folder
geposted Sun 03 Dec 06 @ 11:18 pm
Thanks for the help
geposted Sun 03 Dec 06 @ 11:19 pm
sure :)
geposted Sun 03 Dec 06 @ 11:27 pm
sky,
which database files are you speaking of exactly?
geposted Mon 04 Dec 06 @ 6:04 pm
mp3database.txt
virtualdjdatabase.xml
virtualdjdatabase(yourname).xml
geposted Mon 04 Dec 06 @ 6:54 pm
Sky,
In 3.4, when I use an ext. HD on the backup laptop, I have been first copying the virtualdjdatabase.xml
in the main computer to the backup. Has this been enough for use in 3.4 and still expect to have identical conditions to the main computer.
geposted Tue 05 Dec 06 @ 7:38 pm
yes
but if u use it on a different user make a copy of the file called virtualdjdatabse(yourname).xml
and rename it to ur username on that pc
even better use the same username
geposted Tue 05 Dec 06 @ 10:27 pm
