hi all,
my ivdj has started running slow, switched computer off when it was running fine, then a few days later it was running slow and jerky!! there is a delay between pressing the play button and actually playingand also when i try to scratch, it sounds jumpy rather than smooth!!
please help as its really annoyin!!
geposted Mon 04 Dec 06 @ 7:27 pm
run a full computer defrag
what version you using?
geposted Mon 04 Dec 06 @ 7:44 pm
i will try the defrag, i am using version 3.4-dj console.
thanks for the fast reply
geposted Mon 04 Dec 06 @ 8:07 pm
sure thing let me know how it goes
geposted Mon 04 Dec 06 @ 8:32 pm
i have downloaded that diskeeper program that you mention in your blog and its working as we speak so i will get back to you tomorowto keep you updated!! thanks again!!
geposted Mon 04 Dec 06 @ 8:36 pm
run defrags in both hardrives, ran a disk clean up and still the same problem, also after running program for about three mins,the pc starts responding slowlyto the dj console
geposted Tue 05 Dec 06 @ 9:26 am
try a resinstall of virtual dj and the drivers
geposted Tue 05 Dec 06 @ 10:24 am
re installing the drivers has sorted the delay between console and computer but reinstalling vdj has not worked unfortunately!! im completely stumped
geposted Tue 05 Dec 06 @ 4:16 pm
