I've been in and out of these forums and haven't been able to fins an answer for this problem that I'm having. When using the time coded vinyl, I've found that that pitch slider on the program screen does not follow the pitch setting I am at on the turntable. This is mission critical because I quick mix in most of my sets and not having pitch control is very bad. This problem popped up at my last gig and I had to work extra hard to make the mixes work. (by pitch controlling with the mouse-that suxd big time) After about 30 minutes of that, I switched back to serato and abandoned the VDJ for the night. I'm hoping that its a setting problem but I'm not sure at this point. I'll addendum this post with my computer specs as soon as I get home.
Thanks in advance, just wanted to get the info out there.
geposted Mon 04 Dec 06 @ 10:42 pm
what proformance settings do u have
aslo have u got absolute timecode mode on?
geposted Mon 04 Dec 06 @ 10:44 pm
It's a custom performance setting
Latecy is auto, safe mode and Overclock are un checked. Lowpass filter is 11, enhanced algorithm is 11, and master tempo is fast. Also I'm using relative mode.
geposted Tue 05 Dec 06 @ 1:59 am
