In the performance tab, on the bottom left, there's an option that says "enhanced algorithm", what's the highest it can go to & how does the number affect the scratching if set at optimized for latency? Hope my questions clear ;) Thanks.
geposted Tue 05 Dec 06 @ 2:07 pm
to see the highest it will go drag the slider to best proformance
the number decides i think which algoristhm it uses so a higher number being one of higher quality but needing more cpu
geposted Tue 05 Dec 06 @ 2:26 pm
Thanks buddy. So i'm guessing the highest is 35? That's what it goes to when the slider is all the way to the right. There's one time i put in 99999. :)
geposted Wed 06 Dec 06 @ 2:00 am
