When using beatmatch on console version the cbg would line up with the nearest block however in the pro version it drops back a beat. Can I change this to line up to the nearest in the pro version??
geposted Tue 05 Dec 06 @ 10:47 pm
geposted Tue 05 Dec 06 @ 11:19 pm
My settings are already set to this and it still does the same. If you drop a track in slightly late and then press auto beat for that track it drops back a beat instead of locking to the nearest.
geposted Tue 05 Dec 06 @ 11:57 pm
lower your proformance tab
should help
geposted Wed 06 Dec 06 @ 6:48 pm
or press the pitch bend buttons on your concil
geposted Thu 07 Dec 06 @ 2:55 am
u can do that aslo but hes asking for automix :)
geposted Thu 07 Dec 06 @ 12:05 pm
I have the same problem. When using beatmatch, it drops back a beat
geposted Sat 09 Dec 06 @ 8:36 pm
dont worry guys il try and do some more thinking for u
geposted Sat 09 Dec 06 @ 9:06 pm
skyfxl, does this not happen for you, when beatmaching
geposted Sat 09 Dec 06 @ 9:26 pm
never
it works perfectly
it works perfectly
geposted Sat 09 Dec 06 @ 9:39 pm
lucky for you
I think my specs are ok
Northgate Laptop
P4 2.8
1 gig of ram
Windows XP sP 2
VdJ 4.1rk2
Settings as you have posted in other posts
Connectv Sound card
No other applications installed or running in the background
Northgate Laptop
P4 2.8
1 gig of ram
Windows XP sP 2
VdJ 4.1rk2
Connectv Sound card
geposted Sat 09 Dec 06 @ 10:24 pm
if you like add me on msn ul find it on my blog and il see if i can do any more for you on there it easyer to chat on it
geposted Sat 09 Dec 06 @ 11:25 pm
