VDJ 4.1R2
ASio drivers with ESI U46DJ 1.0.16
The output is not the same on the left and right decks.
The leftdeck outputs stronger and with more kick than the right deck.
This only happens if you use the asio setup.
If you use the 6.1 setup, you do not get this problem.
geposted Wed 06 Dec 06 @ 8:41 pm
choose asio driver as soundsetup
geposted Wed 06 Dec 06 @ 9:36 pm
That is not the fix skyfxl... he said it only happens in the ASIO setup
This is not just a UD46 problem. I have seen some posts right after 4.1 and 4.1r2 releases that stated the variance between left and right decks. I have noticed it as well.
geposted Wed 06 Dec 06 @ 11:18 pm
oops so he did
need another eye test lol
geposted Wed 06 Dec 06 @ 11:23 pm
need to quit posting on every post... that my help your eye sight...
geposted Thu 07 Dec 06 @ 12:05 am
mmmm
interesting but i think il risk it ;)
geposted Thu 07 Dec 06 @ 1:08 pm
