Sorry, I posted this to the software forum by mistake.
I just bought a Dell 1505 laptop for VDJ. Its got the intel dual core, XP professional, 2 G RAM and 100 G SATA 7200 HD.
It came with a sound card.
I would like to purchase VDJ and a DAC 3 controller and add them to my current set up.
I am confused as to the proper way to configure this set up. What type of sound card, internal or external, works best with VDJ? Do I go from my computer to the DAC 3 via USB and from the sound card to my mixer channels (via 1/8 inch to RCA)? I guess I need a sound card with atleast two out puts?? What type of cables should I use?
Any and all advice would be appreciated. Thanks. CM
geposted Thu 07 Dec 06 @ 10:04 pm
as i say what do u want to achive with it?
timecode or just midi control
geposted Thu 07 Dec 06 @ 10:41 pm
I just want to use the DAC controller to mix mp3s, create playlists, automix etc?
Thanks for your help. cM
geposted Thu 07 Dec 06 @ 11:35 pm
yeh build in souncard would be fine for that setup just plugin the dac and ur good to go :)
ul need pro vdj mind u :)
geposted Thu 07 Dec 06 @ 11:38 pm
