I had to reinstall vdj. now my hot cues, and the bpm's of each song is missing. is there a file from my previous install i can drag to the new vdj folder to restore my settings? thanks!
geposted Fri 08 Dec 06 @ 5:37 pm
Yes, the virtualdj database file. It's an xml document. Just copy & paste it in the new vidrtualdj folder. It's always wise to make a back up of this file or even the whole folder before install/re-install.
geposted Fri 08 Dec 06 @ 5:49 pm
there are two. one just saying virtualdj database and the other saying the same thing except it has my name in parenthesis. which do you suggest?
thanks!
thanks!
geposted Fri 08 Dec 06 @ 6:32 pm
Copy the one with your name in parenthesis - VirtualDJ Database (????????).xml
geposted Fri 08 Dec 06 @ 6:34 pm
excellent it worked!
geposted Fri 08 Dec 06 @ 10:46 pm
