I have been shopping pc mixers for quite some time and I am impressed with the software. One question however, is there a way to change the fade in and out points when you are in the auto mix mode. Does it work off decible level? if so how do you change the level so it starts sooner or later.
I am an old school mobile dj so before I purchase the full program, what is the most simple way to connect my pc to my mixer? From what I have read quick way would be to use a fast track pro or a dac unit ... what is your opinion.
thanks for your help,
Scott from the OC
Scott from the OC
geposted Sat 09 Dec 06 @ 2:15 am
skell11 wrote :
is there a way to change the fade in and out points when you are in the auto mix mode?
Yes, right-click on the track that you have on a deck, choose "edit bpm", and select the "Edit AutoMix" tab. Move the track to the point where you want the fade-in point and click on the "Set Entry Point", same goes for exit point.
Next time do a search on the forum first, it's been probably asked many times.
To connect audio outputs to a mixer, 5.1 soundcard and 2 RCA Phono-jack cables.
You can use ANY midi controller to send commands to VDj.
Regards.
geposted Sat 09 Dec 06 @ 9:20 am
