How many of you succesfully use a laptop and bcd200 with no glitches?
I like the bcd2000 more than the hercules, however, ive been doing a lot of reading and i find more problems with the bcd2000 than the hercules. Looking to get one or the other by the way.
geposted Sun 10 Dec 06 @ 1:57 am
It seems to be there are a lot of 'know alls' in this form, especially the kind that know its a really bad product etc etc but have never laid a finger on it.
Your best bet would be to grab one and ensure the store has a return policy. If it doesnt work the way you want it to work, then return it.
One thing i found on this forum was that it was a 50/50 thing with the BCD2000. You have some saying it is garbage and others saying it works.
Buy one and give it a go, if no good, return it.
Cheers,
Steve.
Cheers,
Steve.
geposted Mon 11 Dec 06 @ 3:27 am
common sense? makes sense!
lol
lol
geposted Mon 11 Dec 06 @ 4:38 am
the hardware is fine , but oh my god the drivers!
i hear so many bad things
when u get make sure you check all ur irqs for conflicts
geposted Mon 11 Dec 06 @ 6:30 pm
I can't comment on the BCD because I haven't tried it, but I can tell you that the Hercules MK2 is good. Its buttons have gotten a bit less sensitive over the past year, and the rubbery coating on its jog wheels is wearing through, but it has definitely held up much better than the MK1. I have used it for almost a year putting approx 400 hours on it.
I would like to try the BCD2000 personally, but can't justify it as the Herc is doing the work ;)
geposted Tue 12 Dec 06 @ 4:50 pm
see if you can try one out in ur local dj store ;)
geposted Tue 12 Dec 06 @ 4:52 pm
I've got the BCD2000 and I find it a great product miles better than the herc Mk1 I haven't tried the Mk2.
I do however the odd 'glitch' and it's not enough to drive me mad but I always have butterflies when I'm performing because I'm never 100% confident that the setup will hold together!
I do most of my stuff on FM radio and there's nothing worse than hearing that dead air or having a jingle on repeat whilst i reboot the laptop. lol
geposted Wed 13 Dec 06 @ 8:20 pm
