I think I've asked this begore but there wasn't any ideas given on what might have happened, so here it goes again?
For the second time the left deck all of a sudden, about 3 hours into a show (the first time it was within a half hour). I restarted the program and it was okay?
What possibly could cause this?
I use 3.4 (don't wanna upgrade).
Dell laptop 1 gB ram, happened on both an internal and an ext. sound card at two different times.
Are there any settings I should check for and re-adjust?
Someone please advise. Thank you!
geposted Sun 10 Dec 06 @ 9:45 am
you could be filling up all of your ram
try a free optimisation tool
to clear it when you start to notice lagg
http://www.webmasterfree.com/booster.html
geposted Sun 10 Dec 06 @ 11:14 am
Sky,
Whatya mean by lag, It just "seemed" to happen all of a sudden?
What EXACTLY should I be aware of as far as the "beginning signs of lag", maybe that's my problem??
geposted Sun 10 Dec 06 @ 10:44 pm
songs slight jumps in playing or loading
spining decks spin out of time
il do some thinking for you
geposted Sun 10 Dec 06 @ 11:41 pm
My question would be:
How could my RAM be filling up in less than a half hour of usage using VDJ with no
videos, just the basic song to song for only a few short minutes?
geposted Mon 11 Dec 06 @ 7:45 pm
its just a sugestion but as i havent seen ur pc i cant be sure what services and other processes you have running hiden in the backround
http://www.theorica.net/safexp.htm
try this to shut any unwanted process and services down
geposted Mon 11 Dec 06 @ 7:51 pm
I had the left deck lockup on me for the first time on nye. It was weird. I had to switch to a cd, and restart the program, and it was fine. Kinda scary though. Any solution?
geposted Wed 03 Jan 07 @ 11:02 pm
freak issues can ocur with any program so best not to worry about it
if it happens again please let us know and we can help you :)
geposted Wed 03 Jan 07 @ 11:05 pm
