This is driving me mental!
Ok, I just recorded a 2 hour set, everything sounded perfect when I was doing it, then when I played it back it jumped randomly nearly all the way through...... :(
Any ideas?
Cheers peeps :)
Any ideas?
Cheers peeps :)
geposted Tue 12 Dec 06 @ 11:51 am
what recording options do you have?
Ok, I've got :
Record from master & mic selected (Hercules Dj console mk2 soundcard selected.)
Format : MP3 using lame encoder, Bitrate 128kbs
geposted Tue 12 Dec 06 @ 11:56 am
what pc spec do you have?
geposted Tue 12 Dec 06 @ 12:03 pm
Windows XP Pro
Pentium 4 CPU 1700MHz
1.69 GHz
640 MB RAM
120 GB HD
1.69 GHz
640 MB RAM
120 GB HD
geposted Tue 12 Dec 06 @ 12:06 pm
do you have any other programs open while you record mate?
have you tried replacing the lame codec with a fresh copy
http://www.free-codecs.com/Lame_Encoder_download.htm
geposted Tue 12 Dec 06 @ 3:02 pm
No other programs open
Will give it a go with the new codec
Cheers mate :)
Cheers mate :)
geposted Tue 12 Dec 06 @ 3:55 pm
your most welcome :)
geposted Tue 12 Dec 06 @ 4:05 pm
Ok done a quick test with the fresh codec, still the same..... I cant understand it, it sounds great when I'm doing it, just jumps when I play it back :(
mmmmmmmmm, maybe I could try recording it with blaze and see if that works better..
geposted Tue 12 Dec 06 @ 4:09 pm
try saving as WAv and encode to mp3 ?
geposted Tue 12 Dec 06 @ 4:15 pm
Yep, that works, it's a bit of a pain in the arse file size = 107MB for 3 tunes! and then having to convert it :|, but better than wasting 2 hours on a set and it going to waste :)
Cheers for your help mate :)
xxx
xxx
geposted Tue 12 Dec 06 @ 5:12 pm
I've been having that problem too, when you play you will notice the waves jumping even when not recording thats why when recording it jumps, try to close all other programs and if you have more than one hard drive then set the destination to the drive that is not running virtual dj
geposted Tue 12 Dec 06 @ 10:05 pm
good advice
you may find better results in the 4.1r2 demo
give it a shot ;)
give it a shot ;)
geposted Tue 12 Dec 06 @ 10:42 pm
