hello and can some 1 help,ive just bought a mk2 dj console ,setup went perfect till i tryed to recourd my mix gettin this error **RECORD ERROR** cant open encoder,, i used to use dj console ,had no problems ,ive checked in jd settins for a right .dll file to record to mp3 ,in wav format it say waiting to start ,and when i broadcasting it says broadcasting error and i know it works as i friend has tryed it
any help in this matter would be great
thanks jt
does this work with my broadcasting aswell????
thanks jt
geposted Wed 13 Dec 06 @ 6:57 pm
hi there
http://www.free-codecs.com/download/Lame_Encoder.htm
download this and place it in the program folder of virtual dj
now the problem should be fixed
geposted Wed 13 Dec 06 @ 7:04 pm
