i got virtual dj home when the progam it running i get a buzz when there is no song playing is there a pach to download to fix it as i run virtual dj for my disco is save time and 5 big boxers of cd's + i run a karaoke CD-G is there a virtual dj karaoke player that will work on virtual dj home yours scott www.freewebs.com/asyoulikeitroadshow
geposted Thu 14 Dec 06 @ 2:21 pm
check your cables sounds like grounding problem
geposted Thu 14 Dec 06 @ 2:25 pm
Separate power sources for your computer and mixer.
geposted Thu 14 Dec 06 @ 2:33 pm
Are you using a laptop? If so you could try a power cable without earth wire or get you some ground loop isolators. For more info search the forum on Ground loop.
Ewout
Ewout
geposted Thu 14 Dec 06 @ 8:18 pm
