Could someone locate the DAC-3 Mapper Download, I looked but cant seem to find it
Thanks
Thanks
geposted Fri 15 Dec 06 @ 3:43 am
Click download, plug ins, external tools and you will find the various mappers.
Before you install please read the user guide that comes with it, there specific instructions for specific versions.
Good luck, it's my weapon of choice also,
Rick
Rick
geposted Fri 15 Dec 06 @ 3:56 am
Got it, thanks!
geposted Fri 15 Dec 06 @ 4:03 am
One other issue
I use WINRAR and last time I downloaded the file I had to find the .exe and run it, this time I cant find that. All I see is DACS .dll and .Txt
I dont have my DAC3 connected yet so Im not sure what I did was ok, any suggestions??
geposted Fri 15 Dec 06 @ 4:27 am
put the "dac3.dll" into the C:program files/virtualdj/plugins/control devices folder then activate in the cfg.
There is no .exe
There is no .exe
geposted Fri 15 Dec 06 @ 6:12 am
