Exactly like the subject implies...I would like to have more than one cuepoint for a song but the manual was kinda cryptic...can anyone shed some light?
As always, thanks your your help and time =D
geposted Sat 16 Dec 06 @ 2:03 am
most skins for vdj include 5 cue points pe deck ;-)
geposted Sat 16 Dec 06 @ 2:06 am
click on where you would like a cue , right click and press add cue to go back to it click it or use a keyboardshortcut check my blog for the full list
Where do you right click? The waveform? Cant get the right click function to work on the waveform for some reason.
The way I got it to work is to move the waveform over the "needle" and clicked on any of the 3 cue points and I see a a cue indiactor telling me its number.
How can I get cue 2 to behave like cue 1 in respect to having the ability to hit the "cue" and "play" buttons in the interface or MK2? Problem with cue 2 and 3 is they start and have no way to stop unless I press them again
Man many thanks!
Man many thanks!
geposted Sat 16 Dec 06 @ 2:42 am
They dont stop for that matter just continue to start again from its cue point...no stop and start feature for the 2nd and 3rd cuepoints?
I see that default shortcut for start from cue 2 is alt + 2..but like I said, theres no way to get the 2nd cue to stop..it only starts it..
geposted Sat 16 Dec 06 @ 2:53 am
I think I was having a "blonde moment" over the whole issue.
On the MK2 if you set a 2nd cue point...the master cue works with the cue buttons at top...pressing any subsequent numer at the top initiates the "play" button and the makster "cue" button would initiate the "stop" feature...
Dunno if thats a hack or not but it works effectively =D
geposted Sat 16 Dec 06 @ 3:12 am
click on the progress bar to add cues :)
geposted Sat 16 Dec 06 @ 12:32 pm
Hello -
Kind-of related follow-up question: let's say you have you 5 cue points set up... is there a way (or a skin) that allows you to preview the points *by name* before actually hitting them?
I realize that this can be done while in cue mode, but a list of some kind could be cool. Then again, I guess you could manually notate in COMMENTS part of id3 tag...
Just wondering if any existing solution?
Thanks
Adrian
Thanks
Adrian
geposted Sat 16 Dec 06 @ 10:51 pm
il have an expermiment :)
geposted Sat 16 Dec 06 @ 10:53 pm
