Hey guys how do i copy my cue points from 3.4 to 4.1 , I still have both versions on my computer but in different directories.
geposted Sun 17 Dec 06 @ 11:25 am
copy the files
mp3database.txt
virtualdjdatabase.xml
virtualdjdatabase(yourname).xml
to the 4.1 program folder:)
mp3database.txt
geposted Sun 17 Dec 06 @ 11:41 am
thanks sky
geposted Sun 17 Dec 06 @ 9:33 pm
any time:)
geposted Sun 17 Dec 06 @ 9:48 pm
sky, I checked my files and can not find the mp3database.txt in 3.4 or 4.1 and can't find the virtualdjdatabase(username).xml in 3.4, I found and copied the file virtualdjdatabase.xml from 3.4 to 4.1 with no problem but can't find the other two files to copy , any suggestions?
geposted Sun 17 Dec 06 @ 9:49 pm
do you have all of your cue points ?
geposted Sun 17 Dec 06 @ 9:51 pm
none of them came over and now i can't even start up 3.4 anymore because it give me a installation error when i try to start it , i was only able to copy the virtualdjdatabase.xml file from 3.4, i could not find the other two files to copy
geposted Sun 17 Dec 06 @ 9:55 pm
odear !
could you tell me what error?
geposted Sun 17 Dec 06 @ 10:00 pm
when i try to run 3.4 i get an installation error message, it doesn't sound good!
geposted Sun 17 Dec 06 @ 11:29 pm
in the 4.1 folder what do you have?
geposted Mon 18 Dec 06 @ 12:16 am
