Aplogies for starting a new thread ofr this, I couldn't find my old one.
I have now pre-analyzed all my music, but VDJ still doesn't seem to be able to get control over the gain. Is there something else I should be doing?
The problem I have is when I mix in some tracks VDJ does adjust the gain but often not enough or too much, is this just a limitation of the software? Is there an app or plugin that can equalize gain across multiple files?
Thanks fellas
Thanks fellas
geposted Sun 17 Dec 06 @ 10:06 pm
what gain settings did you pick mate
am i right to say it was always match
and you did it with the any music algorithm?
geposted Sun 17 Dec 06 @ 10:07 pm
Hi mate, seems like you're my personal support contact! ;-)
I analyzed with any music and I've tried both always match and always 0db and on both VDJ deffo does some adjusting it's just that it's often wide of the mark.
geposted Sun 17 Dec 06 @ 10:13 pm
what format are your files :)
geposted Sun 17 Dec 06 @ 10:24 pm
Majority are mp3 some are wma and some wav but only a few
geposted Sun 17 Dec 06 @ 10:34 pm
I just noticed the same trend in my mp3s. I started a new suscription service and the mp3 files are all mostly 192k. Now when I play the old 128k files, there's noticebly a difference in quality and gain which VDJ does not seem 2 compensate. Now my fear is If I up the old several thousand files to say 192k, U can imagine re-analyzing these files and also knowing that some of then were manually adjusted. The database utility has never seem to work 4 me. Bummer!
Mx.
Mx.
geposted Mon 18 Dec 06 @ 3:35 am
So is it the differing bitrates that causes the gain differences?
geposted Tue 19 Dec 06 @ 1:12 am
yes i think so
geposted Tue 19 Dec 06 @ 1:23 am
VDJ can't compensate for quality differences in 128k vs 192k coded mp3s
But as far as gain goes, try reanalyze.
If the files where analyzed in a old version of VDJ, and the new files in the newer VDJ versions, chances are that gain-detection is better in later versions, leaving a difference between old files and new files.
geposted Tue 19 Dec 06 @ 1:34 am
So is there a way to say 're-sample' my files so they play at the same volume? I play on the FM band in london and this is kinda critical to me.
any help apreciated
any help apreciated
geposted Tue 19 Dec 06 @ 12:45 pm
im afraid you cant put back what has been removed
ie droping down to 192 from 320
you will need to take all of your music down to 129 with an mp3 converter program
if you want to do this
which station btw im a londoner :)
geposted Tue 19 Dec 06 @ 4:06 pm
Right so if I understand, I can't increase the bitrate only decrease? Damn that's not good news. :-(
BTW Bassline 97.9FM
BTW Bassline 97.9FM
geposted Tue 19 Dec 06 @ 8:18 pm
Easiest way would be to run a MP3 gain fixer, like this one:
http://www.mp3doctor.com/normalize.htm
geposted Tue 19 Dec 06 @ 8:22 pm
Thanksfor the tip. I'm off to have a look
geposted Tue 19 Dec 06 @ 8:36 pm
What im doing is is using a eq to bump up the freq.
geposted Tue 19 Dec 06 @ 8:46 pm
Thing is with my mixes os that a song might be in for anything between 30 seconds and 2 mins certainly no longer than 3 ins, which leaves me doing a lot of EQing which to be honest also has to be dead on, because my station broadcasts at a certain volume if I mess with that I'll be 'homeless' :(
geposted Tue 19 Dec 06 @ 8:51 pm
a few questions concerning auto gain
i have some issues, too
not so bad with my mp3s, but a lot with my video clips
here are my questions,
- the gain is saved with the other infos(bpm, cues, comments etc.) in the database, right ?
- i'm not sure, but i think changing the performance settings sometimes influences the gain, too, am i wrong ?
depending on the above...
just a few thoughts
how about a option next to auto gain, like reanalyse gain (everytime you load a new track)
or inside the browser, have another option when you right click the mouse
maybe under analyse, have techno/house, any music & gain
so you can reanalyse old gain settings without disturbing your bpm settings
what do you think ?
happy vdjing,
matt
just a few thoughts
what do you think ?
happy vdjing,
matt
geposted Sat 13 Jan 07 @ 11:38 am
maybe also have an option, which makes it possible also to save the gain settings
when you save the database
so, you can adjust the wrong gain settings and save them
which means next time you load the song "your" gain setting will be applied
geposted Mon 15 Jan 07 @ 12:01 pm
