Forum: VirtualDJ Plugins
Topic: Shortcut ?
Is it possible to create a shortcut to the Hecules mapper that switch between scratch and nudge ?
geposted Mon 18 Dec 06 @ 11:24 am
Yes ;) It's necessary to use two buttons for two dedicated panel and link the numer to a special code in the skin, try to analize my skin to understand how you can make it https://virtualdj.com/addons/skin.html?id=1612 ,check the xml code and the special panel number link is write in the end part.
i think , that if u look at the mapper icon on the task bar of your pc theres a menu for this
for quick changing :)
@Cioce i found the part at end of the xml file <DJC am i at the right line ?, but i not really shure what i should look for
@skyfxl . i have seen the meny on the taskbar but i dont want to open it .is it possibel to make a shortcut from the mapper-taskbar menu that switches from scratch to nudge
il check :)
Yes, DJC is the right part of the XML to understand.
<DJC
InvertPitchVolPannel="19"
JogScratchPannel="10"
LoopPannel1="50" LoopPannel2="54"
FxPannel1="51" FxPannel2="55"
CuePannel1="52" CuePannel2="56"
When you enable pannel 10 with skin button the console go in scratch mode ;)
Try to see shortcut for scratch function/hercules dj console explanation here https://virtualdj.com/blog/djjb
The mapper of DJcel disable all the special skin DJ console function.
Thanks . i got it i to work . Got one more problem . trying to get at the pitch to smootly go to zero .but i dont understand the shortcut . ctrl+num *(NUMMULT)
