By the way, if you are looking for a timecode CD, you can download the waveform and burn it yourself on a CD.
The waveform can be found at the bottom of the timecode page
https://virtualdj.com/products/timecode
It's available for free and for everyone.
quote from dev staff..
just bringing it out in the open ;) lol
geposted Wed 04 Aug 04 @ 1:24 am
Hey was wondering. What exactly can be used while using the timecode cd's. Like i know pitch, and scratch was mentioned. What about play/pause, cue, and will it enable use to bend the pitch with the jog wheels, as the dj console does. Also guys just one more thing i would like to ask. I noticed it mentioned that if the needle were to skip VDJ disregards this, and keeps on playing. Does it work the same way with the cd's if the cd were to skip?
geposted Wed 04 Aug 04 @ 8:00 am
Yes if you press play or pause it works.
If you bend the pitch it works.
It should disregard cd scratch's but if its scratched make another copy its free !
geposted Wed 04 Aug 04 @ 8:16 am
