Hi and Happy Holidays to all
I just purchased 2 Numark TT-200 and a 2 channel mixer (I can't remember the model)
I'll also be purchasing the pro version with 3 TCVs (1 as a spare) right after I get the TTs and mixer.
I also have the MKII.
I was wondering what else should I buy?
I'll be doing normal mixing and scratching and I also want to mix videos.
Basically, my plan is this:
The TTs with the TCVs will do my audio/video mixing and scratching
My MKII will act as a MIDI controller and ASIO sound card. So I'll reprogram the buttons on the MKII and use that in collaboration with the TCVs at the same time (as an example, I'll want to use the Cue button on the MKII to jump to a cue point and then scratch with the TTs)
Additionally, when mixing videos, I'll want to use the MKII mixer to mix the audio and the regular mixer for the video (or vice versa).
Do I need anything else?
Is this setup making sense for what I want to do?
Oh one other thing. I see my profile has the DJ console AND the MKII. I gave away the console cause I didn't like it. Is there a way to de-register the console? I didn't see that when I went to https://virtualdj.com/fusers/modifuser.html
Thanks
Thanks
geposted Wed 20 Dec 06 @ 3:40 am
sounds fine
what spec is ur pc?
no but if its crutial
https://virtualdj.com/contact/
support will help you
what spec is ur pc?
geposted Wed 20 Dec 06 @ 3:46 am
Thanks
AMD AM2 3000+ processor (it runs at 2. something I think)
1 GB DDRII
500 GB HDD
32 MB Dual Head Matrox Video card
Of course all the other stuff, key, mouse etc.
I built this PC just for VDJ (it's built into my housing that holds the MKII and mixer - which I didnt get yet). That way I just pick up 1 small box ~(20"x18"x5") and that has everything I need.
The TTs will be in another box so IF I need to carry that, that will be fine too
I was just asking in case my buddy who I gave the console to wants to register, he won't have any problems
Thanks
1 GB DDRII
500 GB HDD
Thanks
geposted Wed 20 Dec 06 @ 11:39 pm
the serial number will be invalid
and you cannot transfer your licence to him
he will need to buy pro sorry
geposted Wed 20 Dec 06 @ 11:45 pm
Hey Skilla!
How do the 200's go? Good for thier price?
Im Just trying to decide what TT's to get... The 200's have been on my list.. But im not so sure about them becuase they are towards the lower range of Numark decks.
Are they worth it?
Thanks mate!
Are they worth it?
Thanks mate!
geposted Fri 22 Dec 06 @ 10:27 am
Phatt B
What's up?
I haven't gotten it as yet. I bought it already but i'm just waiting on delivery (should be a day or two again)
As soon as I get it I'll let you know on this thread.
So I'd say check back around the 1st or so and you'll get a response from me
BTW I've been researching for a while on which one to buy and I decided on the 200's because of price / performance. There may be an issue with how well it holds out over the months / years but other than that I think it should be OK.
Was between the 200, 500 and TTX.
My next step after this might be the ICDX
Happy New Year Man!
What's up?
Happy New Year Man!
geposted Wed 27 Dec 06 @ 6:52 pm
