First off here is a picture of the front and back of the firebox.
www.digitalplayroom.com/presonus/firebox_pic.htm
I was wondering what you to have your settings at, so that I can connect it to my Pioneer djm-3000 mixer, and cue on seperate channels of the mixer, or cueing it up otherwise.
I know how to do the timecode (I think), but if I want to go about it without cd players, how would I do it with the firebox?
Thanks!
Thanks!
geposted Wed 20 Dec 06 @ 3:47 am
choose external mixermode
and assign the channels you want as outputs
hook one out to right one out to left of mixer
for timecode you need a player to play the timecode
you choose timecode mode
then
choose ASIO as a card
then firebox asio driver
then on proformance choose latency auto
then
geposted Wed 20 Dec 06 @ 4:42 am
