i currently use a maya44 but was wondering about the u46dj as its always mentioned as the prefered card to get on this forum.is there any difference between the two besides the u46 having 6 outs over the maya having 4 and the maya not being made no more? is there a difference in the sound..latency..just curious.
thanks
thanks
geposted Thu 21 Dec 06 @ 7:13 pm
to my understanding thats correct
however u46dj aparently isnt going to be made any more either :)
geposted Thu 21 Dec 06 @ 7:17 pm
wow; whats up with soundcard companies?... oh yea ..vista..lol.new os means new drivers for old software/hardware .
well in that case disregard this post heheh.. no need for two discontinued soundcards. lol(just hope my maya keeps going strong till i can find a good back up card or replacement )
geposted Thu 21 Dec 06 @ 7:25 pm
geposted Thu 21 Dec 06 @ 7:38 pm
skyfxl wrote :
Hey Sky...
quick question for ya;
rt now i"m using my dell laditude c640 it works good with video but sonique plugin freezes it not all the time but too often.so im thinking of reinstalling xp on my hp compactnx 9010.what do think of these specs: i tried it beore and my dell performance smoked it but i'm thinking its cause i got alot of ish on m compact (since its my "internet cpu"heheh)
Specifications:
Processor Intel Pentium 4 processors 3.06, 2.8, 2.66, 2.26-GHz, 533MHz FSB,512 KB L2 integrated cache
Memory 2x 512MB DRAM, 1 GB maximum
Hard Drive 40GB
Removable Media DVD/CD-RW, Diskette Drive1
Display
15- inch color TFT XGA with 1024 x 768 resolution (16 M color)
Graphics AGP 4x and 3D Architecture, MPEG2 and DVD playback, standard 64MB shared w/256MB or more main memory, configurable up to 64MB.
Audio AC Link audio , integrated speakers, volume control and mute buttons
Wireless Support 802.11b, 802.11g “pre-standard-g2” or no wireless on select models
Communications Mini PCI 56K (V.92) modem, integrated 10/100 NIC
PC Card Slots One Type II PC Card Slots which supports both 32-bit CardBus and 16-bit PCMCIA Cards
I/O Ports And Connectors Parallel, 1394,USB 2.0 (3), VGA, TV out, RJ-45/RJ-11, Infra Red, Audio in/out
Keyboard Full sized keyboard with five Programmable Easy Access Buttons
Pointing Device Touchpad with dedicated 2 way scroll, On/Off Touchpad button
Operating System Pre-Installed Microsoft Windows XP Professional
Software HP Help and Support
Intervideo WinDVD Playback Software
Safety and Comfort Guide
Acrobat® Reader
Reference Guide Symantec
Norton Anti-Virus
Roxio Easy CD Creator
One Touch Button Software
Microsoft Office on select models
Security Quick Lock
Kensington Lock
Dimensions (H X W X D) 1.73 x 10.72 x 12.96-in /4.39x 32.92x 27.23 cm
1.93 x 10.72 x 12.96-in /4.90x 32.92x 27.23 cm
Weight 7.07-7.69 lbs / 3.2- 3.49 kg
Power Over 2 hours of battery life using the standard 8-cell Lithium-Ion battery, 4.4Ahr, External 90W adapter
Warranty One year Worldwide Limited Warranty
Docking Solutions Port Replicator (available in June 2003)
HP recommends Microsoft® Windows® XP Professional for Mobile Computing
geposted Thu 21 Dec 06 @ 7:56 pm
dj t boogie wrote :
Hey Sky...
Specifications:
Hard Drive 40GB
Display
Acrobat® Reader
Norton Anti-Virus
Security Quick Lock
Kensington Lock
skyfxl wrote :
Hey Sky...
Specifications:
Hard Drive 40GB
Display
Acrobat® Reader
Norton Anti-Virus
Security Quick Lock
Kensington Lock
mostly fine
one possible issue is
share graphics relys on your ram
so this can slow it down
possibly a ram upgrade could fix this
but if you can get the card changed
a larger dedicated one would give you better results :)
geposted Thu 21 Dec 06 @ 8:11 pm
the video card? i maxed out the ram :( it only holds 1gb..
but shouldnt it work better than this?:..
dell latitude c640 Specifications :
Microprocessor types
Intel® Mobile Pentium® 4M
L1 cache
8 KB (internal)
L2 cache
512 KB (on die)
External bus frequency
400 MHz
System Information
System chip set
Intel 845MP
Data bus width
64 bits
DRAM bus width
64 bits
Microprocessor address bus width
32 bits
PC Card
CardBus controller
Texas Instruments PCI 1420 CardBus controller
PC Card connector
two (supports two Type I or Type II cards or one Type III card)
Cards supported
3.3 V and 5 V
PC Card connector size
68 pins
Data width (maximum)
PCMCIA 16 bits
CardBus 32 bits
Memory
Memory module connector
two user-accessible SODIMM sockets
Memory module capacities
128, 256, and 512 MB
Memory type
266-MHz DDR SDRAM
Standard memory
128 MB
Maximum memory
1 GB (i got 2x512mb)
Ports and Connectors
Serial
9-pin connector; 16550C-compatible,
16-byte buffer connector
Parallel
25-hole connector; unidirectional, bidirectional, or ECP
Video
15-hole connector
Audio
microphone connector, stereo headphone/speakers connector
PS/2 keyboard/mouse
6-pin mini-DIN connector
USB
4-pin USB 1.1-compliant connector
Infrared
sensor compatible with IrDA Standard 1.1 (Fast IR) and IrDA Standard 1.0 (Slow IR)
Docking
200-pin connector for a Dell™ docking device
S-video TV-out
7-pin mini-DIN connector (optional S-video to composite video adapter cable)
Mini PCI
Type IIIA Mini PCI card slot with Wi-Fi (802.11b) wireless support
Modem
RJ-11 port
Network adapter
RJ-45 port
Communications
Modem:
Type
v.92 56K MDC
Controller
softmodem
Interface
internal AC 97 bus
Network adapter
10/100 Ethernet LOM
Video
Video type
64-bit hardware accelerated
Data bus
4X AGP
Video controller
ATI Mobility RADEON 7500C
Video memory
32 MB
LCD interface
LVDS
TV support
NTSC or PAL in S-video and composite modes
Audio
Audio type
AC97 (Soft Audio)
Audio controller
Cirrus Logic CS4205
Stereo conversion
18-bit (analog-to-digital and digital-to-analog)
Interfaces:
Internal
PCI bus/AC 97
External
microphone-in connector, stereo headphones/speakers connector
Speaker
two 4-ohm speakers
Internal speaker amplifier
1.0-W channel into 4 ohms
Volume controls
keyboard shortcuts, program menus
Display
Type (active-matrix TFT)
XGA; SXGA+
Dimensions:
Height
214.3 mm (8.4 inches)
Width
285.7 mm (11.3 inches)
Diagonal
357.1 mm (14.1 inches)
Maximum resolutions
1024 x 768 at 16.8 million colors (XGA);
1400 x 1050 at 16.8 million colors (SXGA+)
Response time (typical)
20-ms rise (maximum),
30-ms fall (maximum)
Refresh rate
60 Hz
Operating angle
0° (closed) to 180°
Viewing angles:
Horizontal
±40°
Vertical
+10°/–30°
Pixel pitch
0.28 x 0.28 mm (XGA)
0.20 x 0.20 mm (SXGA+)
Power Consumption:
Panel with backlight (typical)
6.5 W (XGA)
7.0 W (SXGA+)
Controls
brightness can be controlled through keyboard shortcuts
Keyboard
Number of keys
87 (U.S. and Canada); 88 (Europe); 91 (Japan)
Key travel
2.7 mm ± 0.3 (0.11 inch ± 0.016 inch)
Key spacing
19.05 mm ± 0.3 mm (0.75 inch ± 0.012 inch)
Layout
QWERTY/AZERTY/Kanji
Touch Pad
X/Y position resolution (graphics table mode)
240 cpi
Size:
Width
64.88 mm (2.55-inch) sensor-active area
Height
48.88-mm (1.92-inch) rectangle
Track Stick
250 count/sec @ 100 gf
Size
protrudes 0.5 mm higher than surrounding keycaps
Battery
Type
8-cell "smart" lithium ion (4460 mAh)
Dimensions:
Depth
88.5 mm (3.48 inches)
Height
21.5 mm (0.83 inch)
Width
139.0 mm (5.47 inches)
Weight
0.43 kg (0.95 lb)
Voltage
14.8 VDC
Charge time (approximate):
Computer on
2.5 hours
Computer off
1 hour
Operating life
3 to 4 hours with average usage; can be significantly reduced under certain power-intensive conditions
Life span (approximate)
400 discharge/charge cycles
Temperature range:
Operating
0° to 35°C (32° to 95°F)
Storage
–40° to 65°C (–40° to 149°F)
AC Adapter
Input voltage
90–264 VAC
Input current (maximum)
1.5 A
Input frequency
47–63 Hz
Output current
3.5 A
Output power
70 W
Rated output voltage
20 VDC
Dimensions:
Height
27.94 mm (1.1 inches)
Width
58.42 mm (2.3 inches)
L1 cache
8 KB (internal)
L2 cache
512 KB (on die)
400 MHz
System Information
System chip set
Intel 845MP
Data bus width
64 bits
DRAM bus width
64 bits
32 bits
PC Card
CardBus controller
PC Card connector
Cards supported
3.3 V and 5 V
68 pins
PCMCIA 16 bits
CardBus 32 bits
Memory
Memory type
266-MHz DDR SDRAM
Standard memory
128 MB
Maximum memory
Serial
Parallel
Video
15-hole connector
Audio
PS/2 keyboard/mouse
USB
Infrared
Docking
S-video TV-out
Mini PCI
Modem
RJ-11 port
Network adapter
RJ-45 port
Communications
Modem:
Type
v.92 56K MDC
Controller
softmodem
Interface
internal AC 97 bus
Network adapter
10/100 Ethernet LOM
Video
Video type
Data bus
4X AGP
Video controller
Video memory
32 MB
LCD interface
LVDS
TV support
Audio
Audio type
AC97 (Soft Audio)
Audio controller
Cirrus Logic CS4205
Stereo conversion
Interfaces:
Internal
PCI bus/AC 97
External
Speaker
two 4-ohm speakers
Volume controls
Display
XGA; SXGA+
Dimensions:
Height
Width
Diagonal
Maximum resolutions
Refresh rate
60 Hz
Operating angle
0° (closed) to 180°
Viewing angles:
Horizontal
±40°
Vertical
+10°/–30°
Pixel pitch
Power Consumption:
6.5 W (XGA)
7.0 W (SXGA+)
Controls
Keyboard
Number of keys
Key travel
Key spacing
Layout
QWERTY/AZERTY/Kanji
Touch Pad
240 cpi
Size:
Width
Height
Track Stick
Size
Battery
Type
Dimensions:
Depth
Height
21.5 mm (0.83 inch)
Width
Weight
0.43 kg (0.95 lb)
Voltage
14.8 VDC
Computer on
2.5 hours
Computer off
1 hour
Operating life
Temperature range:
Operating
Storage
AC Adapter
Input voltage
90–264 VAC
1.5 A
Input frequency
47–63 Hz
Output current
3.5 A
Output power
70 W
20 VDC
Dimensions:
Height
Width
geposted Thu 21 Dec 06 @ 8:34 pm
btw thanks for helping out
geposted Thu 21 Dec 06 @ 8:37 pm
yes
thats got 32 meg graphics way to small
phone the laptop manufacturers
and ask if any upgrades on graphics are available :)
geposted Thu 21 Dec 06 @ 9:05 pm
There are far better soundcards then u46dj on the market. It all depends on your budget.
geposted Thu 21 Dec 06 @ 10:48 pm
thanks; wil look around some more...
@skyfxl: will do ..gonna call hp...that dell is way too old but its been working flawless xcept with the sonique plug ..i can do exerything else with no problem (just @ minimum performance setting :(
geposted Fri 22 Dec 06 @ 12:48 am
good luck :)
geposted Fri 22 Dec 06 @ 1:01 am
