Can we have a show of hands of those who run Hoster karaoke software and VDJ together?
1) Can you have both running the same time w/o any issues at all?
2) For example, can you minimize Hoster, bring up VDJ and play a few videos, then return to Hoster without any problems at all.
3) What kind of problems do you get when running both simultaneosly?
4) If it can't actually be done, I'm gonna stop trying.
geposted Fri 22 Dec 06 @ 5:43 pm
maybe better to try build in vdj
it might use alot of cpu to use both
swaping between video and kj could be a bit tricky on your second monitor/projector
but should be possible
is there a particular reason you need it?
geposted Fri 22 Dec 06 @ 6:08 pm
Yup, Sky, I do karaoke shows almost exclusively with Hoster as it contains well documented list
of who is next singer and what they will be singing. But once in a while there is a 1/2 hour of music and I like to switch right to VDJ for messing with the video effects , etc.
geposted Fri 22 Dec 06 @ 6:24 pm
I use MTU's Hoster along with VDJ every day. I have never had an issue. Hoster uses very little PC resources
geposted Wed 27 Dec 06 @ 9:03 am
I use Sax & Dotty hoster along with Virtual DJ and never have problems.
geposted Wed 27 Dec 06 @ 6:44 pm
Mdmaxx, what your machine specs that handle this so well,
and when I shrink VDJ after using videos, Hoster seems to not get to the second screen, sort of like as if VDJ kept it to itself and wouldn't give it up.
maybe I need to inactivate video in VDJ before I go back?
have you noticed this kind of occurence at all?
geposted Wed 27 Dec 06 @ 9:43 pm
Bryan you may be able to make a keyboard shortcut to enable/disable your video out from VDJ to use the other software.
geposted Thu 28 Dec 06 @ 1:36 am
for a list of codes and how to make a new one check my blog
geposted Thu 28 Dec 06 @ 1:37 am
Keyboard shortcut =
Ctrl + V
Ctrl + V
geposted Mon 01 Jan 07 @ 5:58 pm
