ok iam log oas Guest and when i analyze all the songs is suppose to close it right? but when i open virtual dj i have to analyze all the songs again iam doing something wrond. iam accesing virtual dj through program and when i click on the short cut i have to enter my serial number all the times i want to use it. can any1 help me on these 2 problems.
geposted Sun 24 Dec 06 @ 3:31 pm
as a guest you cannot make changes to the registry
you need to log on as an domain or local admin
and add your serial
then it will stay ;)
as to the scanning of files you may have installed it to a folder guest cannot write to so your info is lost
i recomend loging in as an admin
or installing to a folder in my documents where you can acess the program
goodluck
and add your serial
goodluck
geposted Sun 24 Dec 06 @ 3:55 pm
