Hi all,
at old 3.4VDJ Version automix with MK2 worked smoothly. Each time it automixed, the AUTOBEAT was turned on to SYNC the beats....perfect for first time at the club not to be mixing manually.
The problem now for me is with 4.1r2 VDJ version. With Automix enabled, the autobeat doesnt work automatically so the songs mix OUT OF BEAT... I need to push manually the autobeat button to make it sync so automix is out of sense if i must be waiting for the mix to manually sync beats.
I tried many configs but i think its a problem of new 4version, is there a way to map this, or to patch this? is ner revision going to correct this bug?
thanks
thanks
geposted Mon 25 Dec 06 @ 2:32 am
Problem Solved...
I just changed audio card config from direct MK2 to ASIO mode. (used to be in WDM)
Thanks
Thanks
geposted Mon 25 Dec 06 @ 5:10 am
