wessmith wrote :
hey dj xeo, when u said the 2 of u make me laugh sometimes,who r the 2 of us????? skyfxl and me??????
I'll answer on his behalf: Yes.
geposted Tue 26 Dec 06 @ 9:24 am
:D thank you dev. team :D no more popping on the headphones from the second card :D
my TCV's like this update more as well ;)
Keep up the awsome work it keeps getting better and better
geposted Tue 26 Dec 06 @ 11:19 am
I don't suppose anyone knows wthat the DAC2 pitch fix was, and if it will also fix those PC's using a mapper? Its mentioned in the history page, but does not explain whet the fix was.
I have the pitch jump issue (Where soon as you move the pitch slider, the software slider jumps to match it) but I'm using Perns Mapper, and not sure if the fix will follow through the mapper to fix both non mapper and mapperd users.
geposted Tue 26 Dec 06 @ 11:47 am
The DAC2 pitch issue was fixed with 4.1r2 - So you shouldn't have issues with 4.2?
How does the pitch respond if you don't use the mapper?
(just rename the dac2.dll to dac2.old and then launch VDJ )
cstoll
cstoll
geposted Tue 26 Dec 06 @ 3:54 pm
I'm afraid I don't have a test DAC here. I'm sort of stuck using the mapper, as it has my video controls built into it.
I will however post here what the results are of running without the mapper.
Would somone be able to foreward whatever fix was applied to the default mapper, to Pern, as his mapper also suffers from the pitch issue?
geposted Wed 27 Dec 06 @ 12:03 am
