Is anyone familiar with the frequency range of the 16 & 32 Band EQ Plugins.
thanks ,<:)+-<
thanks ,<:)+-<
geposted Mon 25 Dec 06 @ 10:23 pm
typically simple equalizer might have bands at 20 Hz, 200 Hz, 2 kHz and 20 kHz, and might be referred to as a 4-band equalizer
geposted Mon 25 Dec 06 @ 10:51 pm
pm the creator of the plugin in question and maybe they will tell you what values they used when they programed it;)
an equalizer with 4 bands is called a 4 band equalizer
geposted Mon 25 Dec 06 @ 11:47 pm
yes , then add the next jumps on in the same pattern.........
add zeros;)
until u get 32
like on a hardware eq
geposted Tue 26 Dec 06 @ 12:00 am
