Ok, well i am a proud user of virtual dj and will be upgrading in a little while unless i set my eyes on something else which hopefully doesn't happen lol, but before i do i want to find out what usb sound card is 30-70 pounds and enables you to connect turntables to it, of course you can guess that i've made the mistake of buying the wrong console and i've gone and bought the dj control mp3 one and not the mpk one or whatever its called. I don't want an expensive one as i am under a budget and of course am not in a club yet or anything and just want to upgrade to vinyl or cds to increase my chance of getting into one.
geposted Tue 26 Dec 06 @ 8:08 pm
Soundblaster LIVE .. The external usb box, with asio drivers
Used it myself, works pretty good:) and is on your budget:)
geposted Tue 26 Dec 06 @ 8:19 pm
yes good card :)
geposted Tue 26 Dec 06 @ 8:29 pm
cool, and it will support all turntables?
geposted Tue 26 Dec 06 @ 8:34 pm
All turntables yes...
But the performance for scratch and such will depend on your turntable (delt or direct drive) and needles... and not so much the soundcard:)
geposted Tue 26 Dec 06 @ 8:36 pm
i know that, whats the best starter one?
geposted Tue 26 Dec 06 @ 8:43 pm
in the range of, lets say 100-200 pounds
geposted Tue 26 Dec 06 @ 8:45 pm
