i have a high-end laptop, singled the problem down to the Hercules....
so far I think the ground-loop thing is the only solution (but havent tried yet), however I dont know exactly how to do it. can i make a cable myself? from what to what do i connect it? somebody throw me a frickin bone here... i just got this thing today and i've been trying to fix this issue for the last 4 hours.
geposted Tue 26 Dec 06 @ 9:57 pm
ok mate its a ground problem ;)
try putting the laptop on a different plug than the amp/speakers
geposted Tue 26 Dec 06 @ 9:59 pm
nope, didnt work....
can i twist some wire and construct a ground cable somehow?
geposted Tue 26 Dec 06 @ 10:06 pm
get a current noise remover
from www.maplin.co.uk
geposted Tue 26 Dec 06 @ 10:08 pm
i live in washington d.c. and am leaving for costa rica in about 4 days. i'll check radio shack for something like what you're talking about. thanks for the tip.
geposted Tue 26 Dec 06 @ 10:21 pm
good luck mate radio shack will have it for sure
geposted Tue 26 Dec 06 @ 10:25 pm
well i went out there and bought some monster cables and 'rf chokes' and it didnt help at all. the same amount of hiss exists and i am a few minutes away from losing my mind completely.
does anyone have alternate solutions?
i looked at my IRQ's and my USB ports are all on IRQ 21 but its not clear which one is for the Hercules MK2.
geposted Tue 26 Dec 06 @ 11:41 pm
what are you using 3.4 or demo?
and what is the mk2 pluged into?
geposted Tue 26 Dec 06 @ 11:44 pm
im using 3.4, and the mk2 is plugged directly into my laptops USB, no USB hub.
geposted Tue 26 Dec 06 @ 11:53 pm
i mean to what speakers ?
just to some crappy speakers i got at the computer store. i have monitors in costa rica but i just needed something cheap here.
however, i have been using these speakers for about a week and there hasnt been a problem. just today i bought the Hercules and now theres hiss everywhere.
geposted Tue 26 Dec 06 @ 11:56 pm
are they plugeded into the same plug socket as ur laptop doe sit still hiss when running on battery?
geposted Wed 27 Dec 06 @ 12:06 am
it still hisses on battery as well
geposted Wed 27 Dec 06 @ 12:51 am
may wana try an external powersource
read the console manual for more info
geposted Wed 27 Dec 06 @ 12:53 am
so i tried it with traktor 3 at a latency of 50ms; it sounds pretty shitty and one of the tracks will just start skipping beats after about 2 seconds.
my laptop is fully capable of handling all these processes without any skipping or lagging... why the hell is this happening? i am not planning on going out there and spending any more money either.
geposted Wed 27 Dec 06 @ 1:09 am
i think its because of ur speakers
geposted Wed 27 Dec 06 @ 1:13 am
well i just tried it with my headphones connected to the output 1/2 and the sound quality is still shitty and the hiss is still there.
geposted Wed 27 Dec 06 @ 1:28 am
K...
Try this:
- Play a mp3 file in Windows Media Player : does it sound good ?
(set hercules to default windows soundcard)
This is to check if its VDJ setting, or the Hercules
A bit of elimination, and we'll find the issue:)
geposted Wed 27 Dec 06 @ 1:34 am
Ok, so you just bought the Herc and now there is hissing - with out the Herc the software is just fine, correct?
Well, could be a bad driver load? Did you download the latest Herc drivers? How about your high-end laptop -- is it up-to date in it's drivers - especially DirectX?
geposted Wed 27 Dec 06 @ 6:58 am
so, things sound relatively normal through media player when the Herc is set as the sound card, however there still is a hiss that messes up the highs a bit.
when i use the Herc through VDJ or Traktor it just sounds ridiculous; like a very very low bit rate. also it'll skip/miss a beat fairly often.
i will update all the Herc drivers again and get back in a few minutes.
geposted Thu 28 Dec 06 @ 11:40 pm
